9.2.10 won't run on Mac OS 10.7.5 (Lion)
Postby muscanto » 08 February 2020, 17:21
Program won't run on 10.7.5. Tried deleting and starting from scratch.
Process: TheLightingController [563]
Path: /Applications/ShowXpress/TheLightingController.app/Contents/MacOS/TheLightingController
Identifier: TheLightingController
Version: ??? (0.1)
Code Type: X86-64 (Native)
Parent Process: launchd [113]
Date/Time: 2020-02-08 11:18:48.766 -0600
OS Version: Mac OS X 10.7.5 (11G63)
Report Version: 9
Interval Since Last Report: 3884958 sec
Crashes Since Last Report: 30
Per-App Crashes Since Last Report: 28
Anonymous UUID: 816AF305-23E2-4E41-BA74-A1F7CF56530D
Crashed Thread: 0
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: /System/Library/Frameworks/AVKit.framework/Versions/A/AVKit
Referenced from: /Applications/ShowXpress/TheLightingController.app/Contents/MacOS/TheLightingController
Reason: image not found
Binary Images:
0x100000000 - 0x1002a6ff7 +TheLightingController (??? - 0.1) <6C4573F2-93E8-3486-B292-4637D686A590> /Applications/ShowXpress/TheLightingController.app/Contents/MacOS/TheLightingController
0x10038b000 - 0x1003b8fe7 libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <6E5C8AC3-DBB7-31CB-BEB7-D6ED8E6DE0CE> /usr/lib/libSystem.B.dylib
0x1003c7000 - 0x1003c7fff com.apple.Carbon (153 - 153) <895C2BF2-1666-3A59-A669-311B1F4F368B> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x1003ca000 - 0x1003dcff7 libz.1.dylib (1.2.5 - compatibility 1.0.0) <30CBEF15-4978-3DED-8629-7109880A19D4> /usr/lib/libz.1.dylib
0x1003e1000 - 0x1006d6ff7 com.apple.security (7.0 - 55148.6) <4535E500-973A-3BA7-AF65-DF5CF0658F02> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x1007f3000 - 0x1007f3fff com.apple.Cocoa (6.6 - ???) <021D4214-9C23-3CD8-AFB2-F331697A4508> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x1007f6000 - 0x1009caff7 com.apple.CoreFoundation (6.7.2 - 635.21) <62A3402E-A4E7-391F-AD20-1EF20236CE1B> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x100b17000 - 0x100b17fff com.apple.CoreServices (53 - 53) <043C8026-8EDD-3241-B090-F589E24062EF> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x100b1a000 - 0x100b6bff7 com.apple.audio.midi.CoreMIDI (1.8 - 42) <D294480D-8E43-3DA6-BD2D-D9FB1102440D> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x100b91000 - 0x100d1cff7 com.apple.QTKit (7.7.1 - 2339) <2BC2CF44-CEAF-3D3B-A250-CA59D6AFB0B0> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff64c70000 - 0x7fff64ca4baf dyld (195.6 - ???) <C58DAD8A-4B00-3676-8637-93D6FDE73147> /usr/lib/dyld
Model: MacBookPro9,2, BootROM MBP91.00D3.B0E, 2 processors, Intel Core i5, 2.5 GHz, 16 GB, SMC 2.2f44
Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In, 512 MB
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1333 MHz, 0x859B, 0x43543130323436344246313333392E4D3136
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1333 MHz, 0x859B, 0x43543130323436344246313333392E4D3136
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xF5), Broadcom BCM43xx 1.0 (5.106.198.19.22)
Bluetooth: Version 4.0.8f17, 2 service, 18 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: Samsung SSD 850 EVO 500GB, 500.11 GB
Serial ATA Device: HL-DT-ST DVDRW GS41N
USB Device: hub_device, 0x8087 (Intel Corporation), 0x0024, 0x1d100000 / 2
USB Device: hub_device, 0x0424 (SMSC), 0x2513, 0x1d180000 / 3
USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0252, 0x1d183000 / 6
USB Device: IR Receiver, apple_vendor_id, 0x8242, 0x1d182000 / 5
USB Device: BRCM20702 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x1d181000 / 4
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x821d, 0x1d181300 / 8
USB Device: hub_device, 0x8087 (Intel Corporation), 0x0024, 0x1a100000 / 2
USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x8509, 0x1a110000 / 3
USB Device: D512, 0x1069, 0x1040, 0x14200000 / 1
muscanto
Re: 9.2.10 won't run on Mac OS 10.7.5
Postby support » 10 February 2020, 11:26
This report says the OS version in your computer is Lion. And it says also that the crash happen in the OS with of some recent code (using AVKit) in our software that is mandatory for Catalina. So we are afraid we can not fix this. Sorry for that.
FYI:
Apple stopped Lion support in year 2014.
V9 is officially suitable for Sierra and more (https://thelightingcontroller.com/viewtopic.php?f=3&t=6)
Return to Mac OS
