SweetLight on macOS Mojave < slow / needs fix
PostPosted: 05 May 2019, 20:22
by havvku
Hey there,
Here I am again with a new issue:
I've been using the 2018 and 2019 on my Mac which I've bought on start of 2018. It was not used for live events, but only for practicing at home. So, I haven't been using it for much.
Since I've installed the 2018 version, I have noticed the lags and slow loading of tabs etc. Now, the V9.15 is out and I've downloaded it, I can still see and feel so much lagging, like I'm working with SweetLight on Windows 98 without being too much optimized.
The only thing I find works without lagging is the 3DView.
And these are my specs: https://ibb.co/k41NxCx
- Hope you fix this, because mac is my fav working station. Thanks!
Re: SweetLight on macOS Mojave < slow / needs fix
PostPosted: 05 May 2019, 21:57
Please try the fix, and let us know if still same.
(https://forum.thelightingcontroller.com/viewt ... =85&t=3438)
PostPosted: 08 May 2019, 00:10
by havvku
Did what you said and what was written on the post, but when trying to enter the software, it shows me this https://ibb.co/gtYBFvM
PostPosted: 08 May 2019, 00:15
by havvku
Found the solution to open up when rewrited here: https://forum.thelightingcontroller.com/viewtopic.php?f=10&p=24873&sid=c9414ac31f4b5d5e6279ce6f9175460b, but after all, it still laggs as hell. Nothing changed :|
PostPosted: 08 May 2019, 09:49
Please try with another new empty lightshow.
In order to know if this problem is exclusively with your computer, that would be great to try with another Mac computer.
PostPosted: 08 May 2019, 21:03
by havvku
Tried by creating a new lightshows, but even that doesn't help.
I truly don't know what is it :roll: would be great if there was someone out there with Mac who could try, because, this is the only one I have
P.S. check this video to notice the lagging points: https://vimeo.com/335000851 PASSWORD IS 243
PostPosted: 09 May 2019, 08:12
The response looks effectively no as good as it is with our computers here.
For other Mac users who read this post, could you please tell us how it is with your Mac computer ?
PostPosted: 07 August 2019, 19:00
by mrchacha100
Just weighing in
Running 2 versions for thew software on 2018 iMac. V) is almost unusable with generators and pixels. Timelines are extremely slow to open. This is on the 64bit version. 32bit still runs better.
Not sure if this helps.
Regards
PostPosted: 25 August 2019, 16:52
by mrchacha100
Another update...generators don’t function properly going between versions...the pan/tilt in a few are completely disregarded. Is this a known issue? Latest fix file installed!
PostPosted: 26 August 2019, 06:57
So after 4 months, only two Mac users have problems with our software !
What about the other Mac users ?
No problem ?
Please give feedback.
