Lightshows from/to Windows to/from MacOS
Frequency Asked Questions
As long as you do not use special characters for the name of the files (fixtures/scenes/...), which are authorized in an OS and not authorized in the other OS, the lightshows are 100% compatible, whatever is the operating system.
To copy them, simply use the "Export/Import lightshow" functions (available from the main menu), via a usb key for instance.
Of course, if you use external media files which are stored out of the lightshow, they will not be copied.
Return to “FAQ's”
