Standalone Power Rating for 1024 Rack
usb to dmx - 1024 dmx channels - 19'' rack - 16 flash buttons - IR remote controller - 8 external contacts - calendar
dgeerchauvetcs
Post by dgeerchauvetcs »
Team
What is the Power rating in Volts and amps for the Rack 1024. It is not listed in the documentation or on the unit itself.
I assume the voltage is 5V - but what is the Max amperage? Just trying to ensure the rack gets what it needs.
Please advise ASAP
Re: Standalone Power Rating for 1024 Rack
Yes, the voltage is 5 V, and the current should be at least 0.5 A (500 mA).
A basic USB power supply will do the job.
dgeerchauvetcs
Is there any danger in running a power supply with a higher amperage rating?
No.
The most important is voltage = 5 Volts and nothing else.
Return to “Rack1024”
