Bug in MIDI response Live Board after program start [fixed]
Arjan
Post by Arjan »
I'd like to report the following bug which exists in both version6.27 and 6.26. If you select a MIDI channel in 'dmx & midi patch' using the combo box the Live Board will respond to this correctly when MIDI data is being received. If you then close SweetLight completely and restart it, Live Board will not respond to incoming MIDI message (even though 'dmx & midi patch' does show that the MIDI messages are being received by SweetLight).
It is only after you go into 'dmx'& midi patch' and use the combo box again to select first some other MIDI port and then the original one again that the Live Board will also start responding again to incoming MIDI.
I'm using MIDI-Yoke (virtual MIDI patcher) to connect my software to SweetLight but I'm pretty sure that this is not a factor. In any case the problem is 100% reproducible. I could try it with an actual MIDI interface with a loopback cable but don't expect this will make any difference. Could you please look into this?
Thanks,
Arjan
Re: Bug in MIDI response Live Board after program start
Thank you for the clear report.
This was effectively a bug.
The fix is available here: http://download.thelightingcontroller.c ... indows.zip
Return to “Buttons”
