Cob Lighting Issues with Pixels [fixed]
DJ Mojoe
Post by DJ Mojoe »
I Have shocker 2 "type fixture" 8 channels. I'm noticing this fixture is under the strobe umbrella. I currently have 16 of these but they are a Chinese brand, 2 eyes that give off a prestige amber color and bright white color. I saw these at a music festival and they are off the hook specially when you do chase effects and use different combos. The club I play at is a luxurious look to it so I'm really hoping I can Xpress can do something with them. Please confirm if they can or cannot be used in pixels as I can't get it to work. Is there any tutorials that can help set up and run combos. Generator or steps etc
I tried using the pixel but I have a hunch they can't be used in there as I attempted adding the chauvet brand shocker 2 but it is not in the library fro pixels.
I tried uploading a PDF file on the fixture info, but I can't upload that file here. Fixture has Dimmer, brightness levels, 0-255 strobe, speed etc, not a complex fixture.
https://www.chauvetdj.com/wp-content/up ... -RIGHT.jpg
Re: Cob Lighting Issues with Pixel
There are some errors in the profile.
Please try the attached one.
We re-made also the library for Editor.
It is here: http://download.thelightingcontroller.c ... or_Editor/
ChauvetDJ_Shocker2(8ch).pxl
(297 Bytes) Downloaded 426 times
Return to “Pixels”
