V9.3.4 - click below fader and it it goes up [fixed]
create scenes with steps
Pauluzzz
Post by Pauluzzz »
I am not sure where to post issues with beta versions, so I post it here.
This one is repeatable, simply in the Editor / Steps screen change from grouping / ungrouping and the sliders block, once moved up, they cannot go down any longer and the ones that were not up yet, just go step by step.
Re: Issues with 9.3.4 Beta
Could you please post a link of a video showing this problem ?
Pauluzzz
Post by Pauluzzz »
Here you go https://vimeo.com/818809400. Sliders go up, but won't go down.
By the way, the fix file includes this beta version, which is the reason I came about it. To get to the latest software I did a complete new install, which is almost fine because it reads the scenes, sounds and videos from the files in the User directory, except for the 2D images files, these I had to copy over.
livetechproductions
Post by livetechproductions »
I've experienced the same issue after installing the fix file (which is the BETA version).
Re-installed using the installers on this website to go back to a working version.
Re: 9.3.4 BETA - click below fader and it it goes up
We will work on this problem asap.
PS: BETA is only because of "DPI scaling" change.
Fixed, and available in the "fix" file (9.3.5 BETA).
https://forum.thelightingcontroller.com ... =85&t=3438
mrchacha100
Re: 9.3.4 BETA - click below fader and it it goes up [fixed]
Post by mrchacha100 »
Thanks for the update but now when saving in a palette the keyboard does not respond with correct characters after pressing spacebar so you cannot save the correct names (if you want a space in the title)
Is this related to this thread ?
mrchacha100
Well the fix for this problem caused a new problem. Would you like me to copy this to another thread for you?
Return to “Editor - Steps”
