3D viewer LED bar always strobing
ColterCreation
Post by ColterCreation »
I've checked the stickied 10+ year old post located https://forum.thelightingcontroller.com ... f=13&t=372, but changing my ADJ MegaBarLED (9ch) dimmer channel to "shutter" and adding a "strobe" level doesn't resolve this issue as the short post says to do. Has anyone else been able to solve this issue where you can't stop the flicker/strobing in 3d viewer? Thank you for your input.
-Colter
Re: 3D viewer LED bar always strobing
Please post the profile (.txt file) of this DMX fixture.
We will check it.
ColterCreation
support wrote:Please post the profile (.txt file) of this DMX fixture.
We will check it.
Thank you. Here it is attached.
MegaBar.txt
ADJ MegaBar 9Ch
(479 Bytes) Downloaded 559 times
Please let me know if you can explain why this is occurring so I can better be equipped to navigate future issues like this. Thank you!!!
Please try the attached one.
We made the changes explained in your first post (https://forum.thelightingcontroller.com ... f=13&t=372).
BUT
the 3 levels (closed, strobe, open) DMX values have to be updated.
We were not able to find the correct DMX values in this manual: http://adjmedia.s3-website-eu-west-1.am ... ar_LED.pdf
because this manual does not show any 9 channels mode.
MegaBar.txt
(513 Bytes) Downloaded 511 times
