Android settings
Android settings
First of all
Connect your smartphone and your computer to the same wifi network.
Live Mobile
- open the "Settings" menu (3 vertical dots)
- Live IP address - enter the IP address of the computer where the software is running
- Live port - the default value (in the app and in the software) is 7348. Do not change this value, except if this port if already used by another software. If you change this value, you will also have to change it in the software (in the "Preferences" of the main menu).
- Live password - enter a 4 digits password ("1234" for instance). You have also to enter the same password in the software (in "Live Settings").
Firewall (on computer)
Make sure your firewall is not blocking TCP communication via port 7348
Software (on computer)
- check the option main menu "Preferences" > tab "Network" > "External app." > "Enable" (and restart the software)
- check the option Live > tool bar > button "menu" > menu "Live settings" > section "External control" > "Enable"
- enter the same password in "password"
- for each page you want to see in Live Mobile, check the option Live > Page (right click) > menu "Visible in external application"
For old software versions only
V7 (year 2014)
- check the option main menu "Preferences" > tab "Network" > "External app." (and restart)
- check the option Live > Settings > External control > Enable
- enter the same password in Live > Settings > External control > password
- for each page you want to see in Live Mobile, check the option Live > Page (right click) > Visible in Live_mobile
V6 (year 2009)
- check the option Live > Preferences > Allow Live_Mobile (and restart Live)
- enter the same password in Live > Preferences > Live_Mobile password
Return to “Android”
