BPM/Beat multiplier feature in timelines? [fixed]
Pauluzzz
Post by Pauluzzz »
Hi there, I was wondering, is there a specific reason why the BPM/Beat multiplier feature (2/1, 4/1 ... 32/1) is not available in the timelines? It is there in the buttons, but not in the Properties of the scenes in the timelines... I'd like to complete scenes (e.g chaser) consisting of 2 or 4 steps in one beat, what I do now is multiply the BPM by 4 and set it in the timeline by means of the BPM tool, and then calculate for each newly added scene the BPM it requires, but wouldn't it be more logical to have this done in the speed properties just like the buttons)? (And en passant remove the limit of 500...)
Re: BPM/Beat multiplier feature in timelines?
Yes, this makes sense.
Added in ToDo list.
Done in the fix file.
Pauluzzz
Re: BPM/Beat multiplier feature in timelines? [fixed]
Post by Pauluzzz »
Great, works as a charm, I like fix files.
But, are the BPM steps namings properties correct ("Txt_BPMSpeedStep" instead of simple "Step")?
Did you also replace the folder "language" ?
https://forum.thelightingcontroller.com ... =85&t=3438
When there is a folder called "language", this means the text in the software has been updated. To see this new text in the software, please copy the ini files ("english.ini", ..., "spanish.ini") in the folder "../language/" of your software.
Pauluzzz
Post by Pauluzzz »
No, I hadn't indeed, just done so and now works well. Thanks!
Return to “Live - TimeLine”
