LED Splash200B [fixed]
pogjack
Post by pogjack »
Unless i have an old copy of the LED Splash200B the channels need a little tweeking. Channel 5 needs an open from 1 to 21 (only strobes when a color is turned on). Channel 6 (dimmer) needs to have the reverse dimmer checked (b/c for some reason they made it that way).
Other than that, is your software setup so that it can utilize this light as designed (I guess for 3D purposes). The other channels are dependant on what channel 1 is set on. Ex. Channel 1: 0 - 29 the other channels are Rd, Grn, Blue, strobe, dimmer, but if channel 1 is set 120 to 149 (color macros), then channel 2 (which is normal LED red) is a color macro 0 - 255, and 6 is still dimmer, but all other channels are nonfunctional.
And one final question. Is there a way to reverse the dmx signal sent out. For example, channel 6 is made so that the dimmer works backwards (yes, I contacted chauvet and they confirmed it). Can I set that channel so that when I increase the fader it will increase the dimmer and not decrease?
Thanks,
Re: LED Splash200B
1. Our software is not able to dynamically change the channels setting of a fixture. This means you must chose one channels setting (channel #1).
2. Yes, it is possible to reverse the channel "dimmer" in 3DView.
Setup > fixtures setting > 3DView > check the option "Reverse dimmer"
Return to “Setup”
