Intimidator Spot 260 channel issue
post here other topics
Demimage
Post by Demimage »
So i was just wondering... in the user manual Channel 8 states the following parameters:
(Gobo Rotation) CH8
001-007 no function, 008-119 clockwise rotation speed slow to fast, 120-231 counter_clockwise rotation slow to fast, 232-255 bounce slow to fast.
On the .txt document and on the parameters of the fixture when loaded into showxpress it states
(Gobo Rotation) CH8
001-63 index, 64-145 right rotate, 146-149 stop, 150-231 left rotate, 232-255 shaking
Which one is right? should i manually change the parameters to match the manual or is the .txt correct?
Please help.. :)
Re: Intimidator Spot 260 channel issue
Could you please post the link to the manual showing these different values ?
Return to “Other”
