I can not open an application (it was ok with 2 monitors)
All applications remember the window size&position, before closing. So there is a good chance that the application was in the second monitor, and the software still open the application in the second monitor (even when not used).
This problem will be fixed for next software versions. In the meantime, you can do this:
- ControlBoard > Settings > open lightshows folder
- open "../LightShows/YourPersonalShow/Live/Live.ini" (depending of the not visible application, change "Live" by "Setup", "Editor" or "3DView")
- in "Live.ini", delete the line "Frm_Main = ...|...|...|...|."
- save and close "live.ini"
Next time you will open Live, it will be located in center of main monitor.
Caution: modifying a .ini file can potentially damage your lightshow. We strongly suggest you to make a backup of your lightshow, before doing this operation.
