Crash when selecting mono + multi heads fixtures [fixed]
create scenes with steps
sgriffin1
Post by sgriffin1 »
Using 4 Intimidator Spot 455's and also 2 Intimidator Spot Dou 155's. Every time I select all these fixtures in steps, then try to position them, program crash....
Re: Version 9 repeated crash
Please post a link to download your lightshow (https://forum.thelightingcontroller.com ... ?f=3&t=168).
We will check that.
Thank you for your lightshow.
Fixed in the fix file (https://forum.thelightingcontroller.com ... =85&t=3438).
sgriffin1
Re: Crash when selecting mono + multi heads fixtures [fixed]
Post by sgriffin1 »
Thanks for checking out the problem! I am very happy with v9. I have run this version for several 4 plus hour shows with no problems. Just happened to find this one problem and wanted to let you guys work you magic on it. Keep up the good work!!!!!
Return to “Editor - Steps”
