Tomshine 40W Stage Lighting 12 LED RGBW
djayabsolute
Post by djayabsolute »
I created a
Tomshine led mini moving head light 12pcs.txt
(992 Bytes) Downloaded 1167 times
13 channel profile for this fixture however, i don't think it is working right in the 3d view. the color changes however there is no strobe. channel 12 seems out of order because of the dmx value in the manual
tomshine manual resize.jpg (184.42 KiB) Viewed 8877 times
. I also notice that the manual does not say the make of the fixture. on amazon where i purchased the light, description states that it is a 14/16 channel dmx light but the manual that came with it says 7/13 channels. i have attached the manual with this message. can someone help? thanks
Gilles
Re: Tomshine 40W Stage Lighting 12 LED RGBW
Post by Gilles »
Tu avais plusieurs erreurs, essaie le fichier ci-joint, mais il faudra que tu rentres tes valeurs du pan et tilt.
Attention, si tu es sur la version 8, il y a un correctif ici https://thelightingcontroller.com/viewt ... =13&t=5432 pour le random et pulse (pour le canal 12).
(717 Bytes) Downloaded 1099 times
djayabsolute
thank you i will try it
Return to “Editor - Fixtures”
