I do not see the fixtures [fixed]
Focu
Post by Focu »
When I open 3d renderer I do not see the fixture but the fixtures setting tab is not actin. :(
[image]
Re: when you activate the 3d version of V8, you can not see
Looks like firewall/antivirus blocking problem.
Please read this: https://forum.thelightingcontroller.com ... f=13&t=834
Focu
Re: I do not see the fixtures
Post by Focu »
it did not work, I tried to disable the firewall, create new rules, remove the full program and re-install, nothing happens.
so I installed v9 there fixtures are visible but I can not manage them.
F.SEGUIN
Post by F.SEGUIN »
In the fixture setting, dbClick on "Moving ligt spot" for open the Device editor and look if the 3D view is selected with a device. If the 3D view selected is "not in 3DView" The device is not displayed in the 3D view.
Focu
Post by Focu »
No, the device is not visible
Focu
Post by Focu »
I found a solution. Just need to change the ip address to 127.0.0.1. Maybe someone it will be useful. ;)
Thank you for the feedback.
This IP address is supposed to be the default IP address in the software parameters.
Please let us know if it was another IP address after first software installation.
Focu
Re: I do not see the fixtures [fixed]
Post by Focu »
I'm not sure that this is a problem in v9 because on the other computer it was all good
