Can you use a external 3d view?
Mashout
Post by Mashout »
HI all,
Can we use a external 3d vieuw like Capture via Artnet?
Greetings,
David
Re: Can you use a external 3d view?
Our software is able to output the dmx channels via Artnet.
Beyond that, we do not know.
BartKrap
Post by BartKrap »
Mashout wrote:HI all,
Greetings,
David
Yes you can via artnet in on Capture. Just note that you do need to at least one interface connected to be able to output artnet.
Shakes
Post by Shakes »
BartKrap wrote:Yes you can via artnet in on Capture. Just note that you do need to at least one interface connected to be able to output artnet.
When you say one interface, is that an Artnet interface or a lighting controller DMX interface??
SeekLighting
Post by SeekLighting »
You always need a Lighting Controller interface to unlock output. One Interface connected provides 2 universes - one over the interface via DMX and another via artnet, output from the Computer's Ethernet port. You would need to purchase an artnet node to convert this artnet signal back to DMX.
