Height Dimensions
Height Dimensions
Would you please confirm the total height of the unit from tabletop, it's published at 46mm but need to make sure it will fit under a 50mm high space and not be compromised by stand off rubber feet.
Re: Height Dimensions
We doublechecked.
We found 46,3mm.
So we guarantee less then 47mm.
And there is no ruber feet.
We found 46,3mm.
Thanks for the quick reply, I am building a custom laptop & ipad shelf and require that the Remote box fits under it. I can now go ahead and build it with a 50mm clearance.
