Generator issue- specifically moving lights [fixed]
create lighting scenes
Mikael81491
Post by Mikael81491 »
Just noticed an issue with the effects generator...
When creating any sort of movement curve such as a circle, figure 8, etc with a curved moving pattern and not a straight line, there is an issue when sending the scene from the generator to the main editor. When doing it with either a single fixture or a set of fixtures that aren't set to shift, it turns the circular movement pattern into one made entirely out of straight lines, thus ruining the effect. When choosing to shift the fixtures, however, this problem is not as apparent.
Re: Generator issue- specifically moving lights
We just made this topic for that: viewtopic.php?f=11&t=551
Return to “Editor”
