[request] X/Y Separation
Clgsound
Post by Clgsound »
In generator can we have a way to separate the x and y so I can make a movement with only X or only Y.
Re: (Request) X/Y Separation
No, it is not possible to separate the pan&tilt channels.
AV Concepts TT
Re: [request] X/Y Separation
Post by AV Concepts TT »
Try locking the X or Y then generate the movement
samwise309
Post by samwise309 »
Are you trying to get a "relative" X or Y movement? i.e. your beams are in some position and you just want them to move X or Y?
Clgsound
Post by Clgsound »
samwise309 wrote:Are you trying to get a "relative" X or Y movement? i.e. your beams are in some position and you just want them to move X or Y?
Correct. I know how to achieve this by generating my pan or tilt movement, adding to stand alone, uploading, going into editor, load the stand alone scene file, select lights and disable which ever axis I don't want. Thats a lot of steps to be doing every night. seems like with RGB grouping in generator it wouldn't be hard to have X/Y grouped or ungrouped and would save time.
