ArtNet to DMX
computer, driver, ...
jamesford25
ArtNet to DMX
Post by jamesford25 »
I'm trying to use a cheap USB to DMX512 adapter, everything is installed with other software and is working.
Assuming you don't support it the uDMX dongles what ArtNet Software is compatible with ShowXPress?
:D
Re: ArtNet to DMX
jamesford25
Re: ArtNet to DMX
Do you allow support for ArtNet Software for Windows or just via those devices?
Re: ArtNet to DMX
Sorry but we do not understand your question.
jamesford25
Re: ArtNet to DMX
I'm trying to use a cheap USB to DMX dongle but I haven't found a way to use it with ShowXPress. If there is a way of doing it, that is what I'm trying to find out. Whether it can work straight out as DMX or having to use ArtNet Software on Windows to bridge between ShowXPress and the DMX Dongle.
In short I'm trying to find a way to use a cheap USB to DMX Dongle with ShowXPress, as we have no money to spend due to working with a community group, we could not afford the Chauvet USB Dongles
Re: ArtNet to DMX
Understood.
Sorry, but it is not possible to control any fixture without having one of our interface.
ryvanz
Re: ArtNet to DMX
Post by ryvanz »
support wrote:Understood.
What about the Chauvet ArtNet products like Net-X? Will it work with ShowXpress?
https://www.chauvetprofessional.com/products/net-x/
Thanks!
Re: ArtNet to DMX
ryvanz
Re: ArtNet to DMX
Post by ryvanz »
support wrote:No.
viewtopic.php?f=3&t=5
In that case, which ArtNet interfaces will ShowXpress work with? There aren't any on that page that are still available, and the ones that are available such as the D512 do not have ArtNet capabilities.
Re: ArtNet to DMX
Our software sends Artnet via the computer Ethernet port.
You have to connect your Artnet lighting fixtures to the computer Ethernet port.
Return to “General hardware”
