V8 - Master Faders
Clgsound
V8 - Master Faders
Post by Clgsound »
The more I use V8 I love the speed controls. The only down side is all 4 are used for different speed controls. I now have my dimmers on 2-step scenes. This is a problem, I can't kill the lights while dimmer chases or certain effects are going because they then take over and they lights come back on.
Is there a way in a future update to duplicate the master section so there are more faders available? Or make a tab that is dedicated to master faders instead of the right side of the screen?
Re: V8 Master Faders
Please keep in mind that these 4 faders are "masters", which means proportional adjustment.
While you can insert standard faders for speed and dimmer inside each button.
BartKrap
Post by BartKrap »
support wrote:Please keep in mind that these 4 faders are "masters", which means proportional adjustment.
Actually I've been having trouble with that, when I move my fader past 10% the lights just goes to 100%.
This only applies for version 8.1 and the fixes won't install on my pc.
Re: V8 - Master Faders
The fix file contains updates regarding your problem.
Please read this to install the fix: viewtopic.php?f=3&t=3438
Clgsound
Post by Clgsound »
I've been having an issue with my dimmers that seems opposite of you. I'm on the latest fix file. When i have a 2-step scene for my dimmer if i go to 100% my lights cut off. so in editor i have to tell my lights to go to 254 not 255.
Also I may be confused about what you are saying in your last post support (insert standard faders) could you explain that a little more? maybe i haven't had enough coffee this morning. By standard fader do you mean right clicking and choosing fader button? but then how do you have a "master" control of speed if I make them individual fader buttons.
Please post your lightshow, and tell us how to see that problem.
Please read this for Master Faders and Sliders: viewtopic.php?f=72&t=3647
Clgsound
Post by Clgsound »
Sorry I didn't clarify more. this is when I have the button set to a fader button and mapped to a Fader on my APC20. when my APC fader is pushed all the way up the lights cut off. If I click the fader button in live with a mouse they do not cut off. but this has happened with different controllers I've tried not just the APC20.
Clgsound
Post by Clgsound »
Yes I understand the two fader options. Im just unable to do what I would wish to at the current moment I guess. For me there is no point in having my dimmer effects and color effects on individual speed controls. I want all scenes to be playing at the same rate. When I program, all my effects scenes have the same overall time so I can use a speed fader to control all.
My problem comes from there only being 4 Masters Speed/Dimmer.
I have them all set to speed controlling, XY positions, Movement speed, Dimmer effect speed, Color change speed.
I also need a master for each of my fixture types and by creating a fader button in Live it doest do as I need because if a scene with a dimmer effect is active it will overtake what I call my master.
I can't activate buttons with my master off because if I activate a dimmer effect with my current master off when I turn it on the software see them as being whatever % they are instead of running the dimmer effect.
Idk much about software programing but would there be a way to duplicate your programming and bump the masters speed/dimmer up to 8 in the drop down menu.
Or could i send you my show and you make the changes you're speaking of and send it back. maybe I'm just confused by your wording.
Clgsound wrote:Sorry I didn't clarify more. this is when I have the button set to a fader button and mapped to a Fader on my APC20. when my APC fader is pushed all the way up the lights cut off. If I click the fader button in live with a mouse they do not cut off. but this has happened with different controllers I've tried not just the APC20.
Fixed for next fix file.
MTFentertainment
Post by MTFentertainment »
I would like to second this request. I also like to use the proportional faders to control fixture and effect types. 8 fader would be very useful. They do not all have to be visible because they will be midi mapped.
Thanks guys!
