[Request] "Command Input "
create scenes with steps
Lighter007
Post by Lighter007 »
Here's a feature request for v8 Editor:
You type in a number (DMX adress) and then press something like '@' and then a number between 0 and 100 (%). -> Sets the selected channel at the level typed in.
You should also be able to select multiple channels via '+' and something like '1' '-' '4' selects channels 1,2,3,4 (minus key in this example but could also be another). There are also more possibilities like 'D' for deactivate channels etc.
Why? This would make programming much faster sometimes and makes the Software more professional; all professional lighting consoles have got this feature.
Would be great if this would be introduced.
lighter007
Greetings from Germany! :)
Re: Request: "Command Input " in Editor
Moved in "Editor - Steps" (section "V8 Alpha" is presently only for V8 feedback).
You can select multiple channels with keys "ctrl"/"shift" + mouse click.
Return to “Editor - Steps”
