Blizzard - Solar Ray
raverezra
Post by raverezra »
Requesting profile for Blizzard Lighting SolarRay
link to “Solar Ray Manual Rev A (Web).pdf” in my Dropbox:
https://www.dropbox.com/s/lxxcvghqhobf0 ... 9.pdf?dl=0
SolarRay™
Ultra Bright Warm White
5x5 Pixel Matrix Blinder
Meet the SolarRay
FEATURES:
25* high efficiency 3-Watt Edison LEDs
Projects intense narrow beams of 2,800k warm white light
Flexible panel system with integrated locks
Easy configuration and setup via built-in LCD control panel
Individual pixel control in 25-channel DMX mode
29 built-in programs + auto run with speed adjustment
Kling-Net/Art-Net support allows auto-configuration over Ethernet
8° beam angle, pitch: 60 mm
DMX Channels: 6/25
Strobe Rate: 0-20 Hz
Strong cast aluminum housing
Internal Protection: IP20
Smooth dimming curve with flicker-free operation (400Hz)
High-performance fanless convection cooling
Mounting bracket with dual locking knobs & ¼ turn quick clamp bracket
2x RJ45 Ethernet in/out data connections
3-pin DMX input/output
PowerCon™ compatible AC power in/out connectors
TECH SPECIFICATIONS:
Weight & Dimensions
Width: 11.8 inches (300 mm)
Depth: 3.8 inches (96 mm)
Height: 11.8 inches (300 mm)
Weight: 8.9 lb. (4 kg)
Power
Operating Voltage: 100-240VAC, 50-60 Hertz
Power Consumption: 75W, 1.02A, PF: .61
Light Source: LED 25* 3-Watt Edison 2,800k Warm White LEDs
Optical
Beam Angle: 8 degree
Luminous Intensity: 13,500 Lux @ 1m, 5,120 Lux @ 2m
Pixels: 5 x 5
Pixel Pitch: 60mm
Thermal
Max. Operating Temp.: 104 degrees F (40 degrees C) ambient
Control
Protocol: Art-Net™, Kling-Net, USITT DMX-512
DMX Channels: 6/25-Channels
Input/Output: 3-pin XLR Male/Female
Other Operating Modes: Standalone, Master/Slave, Auto, Sound Active
Re: Blizzard Solar Ray
Done.
