APC Key 25 (full control of fade in fade out dimmer on knob)
How can i have full control on the dimmers fade in and fade out on a knob, if possible? For Midi Out(Data 2 ON) what should it be set at also for Midi Out (Data 2 OFF)?
HELPPP! ASAP!
Re: APC Key 25 (full control of fade in fade out dimmer on k
What do you mean by full controll?
I can guess you have a button in Live that you contoll with a knob using midi. This button contoll dimmer channel?
If so, only other buttons that also use the same dimmer channel can complicate things for you.
If you are using any other approach, then we need more explanation.
Thore
Using HW: D1024 & D512
Controller: 2x Akai APC mini
my DIY light mixer
my DIY light mixer
