Driver problem [fixed]
LT1
Post by LT1 »
Hi all -
I just bought an unidentified USB dongle which looks like this.
The previous owner said he thought he'd used "Showtime Express" on a Mac.
When first connected, I see this in Device Manager (Windows 7, 64bit):
If I download the drivers from this forum and point the entry at the folder, I get this:
...install...
I then get the Cable driver appear in Device Manager, but also the rogue "USB Serial Port" entry that's cropped up on the forum before.
I can't get rid of this. If you uninstall it, it just reappears. If you point it at the drivers folder, it's not interested.
If I then run ShowXpress, it doesn't like the dongle.
When I run USBVIEW I see this:
I also tried installing Sweetlight, and that does seem to recognise the dongle and let me into the program.
I still can't get rid of the "USB Serial Port" entry however, even with the Sweetlight drivers.
I could disable it and ignore it...I haven't actually managed to get the interface working with lights yet, but that's probably just my ignorance of the software. Before I go any further however, could you confirm whether it ought to be working or not, given the above...? I still don't know for sure exactly what this dongle is, or the software I should be using with it.
Thanks!
Re: Driver problem
Your interface is a SweetLight interface.
So you have to use it with a SweetLight software.
Caution: this interface does not work under MacOS (viewtopic.php?f=16&t=30).
LT1
Re: Driver problem
Post by LT1 »
Thanks - so what about the error on the "USB Serial Port" in Device Manager...? Does it matter, or can I just ignore it...? (I've tried this on three machines - two Windows 7 32bit, and one Windows 7 64bit, with identical results.)
Re: Driver problem
We just made a new topic regarding the "usb serial port driver" problem here: viewtopic.php?f=16&t=3611
Please read it.
syxawa
Re: Driver problem
Post by syxawa »
Eh ...bah ....Voila... j'ai exactement le même problème : ... there is one not compatible interface. please remove it..."
J'ai installé ... des-installé... réinstallé... je ne sais plus quoi faire... Désespérée...
J'ai regardé tous les topics...
Merci de votre aide
Re: Driver problem
Il doit fonctionner avec un des logiciels (Windows) se trouvant ici : viewtopic.php?f=3&t=114
syxawa
Re: Driver problem
Post by syxawa »
J'ai essayé... en utilisant les liens de ce fameux topic... mais rien à faire...
Lorsque je branche l'interface... Il m'installe automatiquement DMX Câble... Je ne peux pas l'en empêcher... En allant dans Panneau de configuration, puis gestion des périphériques, je mets à jour manuellement le pilote... et le pilote s'installe (cable interface V1.06). Et ensuite, Je supprime le USB serial port (qui lui est resté !)
Je lance Sweetlight (... ou Showpress...ou)... et il me dit "There is one not compatible. pleas remove it"... Le logiciel ne démarre pas
Si je retire le cordon USB, le logiciel démarre... mais evidemment, il ne voit pas l'interface...
J'ai déjà tout desinstallé... en tout recommencé...
J'ai essayé sur un portable TOSHIBA (Win Vista).... même résultat !
Re: Driver problem
Si l'interface n'est pas trouvée par tous les logiciels se trouvant ici viewtopic.php?f=3&t=114, elle est peut-être défectueuse.
Ceci dit, ce serait surprenant, car l'ordinateur installe correctement son pilote.
syxawa
Re: Driver problem
Post by syxawa »
Je suis bien d'accord...J'ai l'impression de tourner en rond...
J'ai acheté cette interface chez music store (ref. : LIG0002896-000)
J'ai pensé aussi que cela pouvait venir de là. Je leur envoyé un mail, pour avoir aussi de l'aide, mais ... pas de réponse...
syxawa
Re: Driver problem
Post by syxawa »
Ouf... ça fonctionne...
Après avoir, une nouvelle fois, tous des-installés, ... J'ai réinstallé QuickDMX... (Le seul que je n'avais pas encore essayé !!!) ... et là, sur mon PC (Win7)... il a marché du 1er coup... ... et sur mon portable Toshiba (Vista) ... au2nd coup, car il a fallu que je mette à jour le pilote ( Cable interface 1.06)
Merci
Return to “Cable”
