§D Animation not smooth working
MTF Showtechnic
Post by MTF Showtechnic »
Now it is possible to select the refresh of the DMX Output and the Display.
And this is what our Test PC will do: The 3D won’t work smooth. If a light fade in it looks a little bit like working as a lot of steps one after the other.
I’ve seen that behavior on an old Laptop with 6.xx Version. PC also to old?
The complete screen flashes sometimes. Is this the refresh of the display?
greatings
Re: §D Animation not smooth working
We suggest you to install the latest driver for your video card.
This oftenly helps.
If no change after fresh video driver, the PC might be effectively to old.
And maybe the framerate in 3DView parameters is too low.
