Copy & paste
create scenes with steps
audiopyle
Copy & paste
Post by audiopyle »
In the editor I am able to copy dmx values from a group of fixtures in one scene and paste them to the same group of fixtures in another scene. When pasting the values to STEPS of a scene, there is a choice in the menu to "paste on this step only" or to "paste all steps". Only the single step option seems to be working. If I click to "paste all steps" it will either paste to only the step that is highlighted in the step list, or it will not paste at all. To get around this I can paste the settings to a single step, then select the "set value of selected channel on all steps" from the menu, but it seems the "paste all steps" command should perform this function with a single click. Perhaps I misunderstand the command?
Also, if it were possible I think that an "undo" button in the program would be great, even if it could only undo the last action.
Re: Copy & paste
"paste all steps" copies all steps from source to all steps of target
Noted for ""undo".
Return to “Editor - Steps”
