New "speed slider" for buttons
In this beta program Live (beta), you can assign one speed slider for each button. To add the speed slider, right-click over the button and select "Scene settings".
eedetail
Re: New "speed slider" for buttons
Post by eedetail »
Cool, I look forward to testing it tomorrow in a smaller show.
I also like the "Loop" option, will test it out.
FraBob
Post by FraBob »
very very good!!
eedetail
Post by eedetail »
I ran it 4 hours sat nite, and did not notice anything not working.
Only used two smaller moving heads, but it worked as far as their max speed.
Only ran chases on rear led wash panels, but it went fine there too.
Thank you as always support for your hard work.
I like the ability to label the master sliders as well.
TimE
Thank you for your feedback,
fedo
Post by fedo »
super la fonction speed slider tant attendue sera t il possible de l affecter a un fader de ma bcf 2000 ?
C'est normalement déjà possible, dans Live > Préférences.
DJ Trenco
Post by DJ Trenco »
I have a request. I use these speed sliders a while and it works brilliantly! But I also use a midi controller, what I really want is that I can have 2 different midi values for 1 button. so I want one channel for the speeds of my scanners and one where I can actually trigger the show. If this is possible then I can give all my scenes one slider for the speed and then several buttons for which show I want to play. At this moment if you chance the speedslider of a button it automatic triggers the button. I hope everything is clear?
In the beta version of Live (http://download.thelightingcontroller.c ... ware/beta/), you can add a speed slider in each button (right click on button and select "scene setting"). The slider can be linked to a midi fader.
DJ Trenco
Post by DJ Trenco »
I know, and I use the speed fader already. But I want 2 midi channels for one button. One for the speed and one for the trigger (button). At this moment I can only link one button at one midi channel.
Return to “Buttons”
