hello!
is it possible to insert a slider in the live instead of a button?
this to a smoke controller
this slider should have effect on one channel.
thanks for reply
Slider in "live"
Re: Slider in "live"
You can put a scene with some steps in one button.
Afterwards, you set this button as "Preset" (right click over the button and select "Preset").
oke i understand.
but if i look at the martin light jockey they have a popup screen when we select the hazer. whitin the popup smoke and fan.
is this possible to develop?
greetz
greetz
Live pages & buttons is customizable.
You can add any button linked to any scene you want.
I created two light scenes called Hazer1 and Hazer2. Hazer1 has five steps. Each step increases the dmx out value for the hazer "haze" channel. Each step is about 20% output up to the max of DMX 255. Scene Hazer2 is built the same way except it controls the Hazers "fan" channel from 0 to 255. Now you can add two buttons to your show for these scenes and make them preset buttons. This will apply a fader looking control to each of the buttons. The faders will select each of the steps from 0 to max output for your haze and your fan.
