UI Suggestion - dark instead of standard white/grays
gilsontech
Post by gilsontech »
I was at a show this weekend and was running ShowXpress with 3 monitors and the stage is about 250 feet away from me and i have to blackout the stage a lot. I find myself turning the lcd screens brightness way down. I also design using Photoshop and noticed in their new version (CS6), they made a new improvement to the UI that I find myself liking more and more. They made the UI dark instead of the standard white/grays. I would like to recommend that for ShowXpress, maybe a dark UI option. Thanks!
-Josh
Working on the next BIG thing
Re: UI Suggestion
Not easy because using standard Operating System gadgets (color usually can not be changed).
Regarding buttons, you can set dark colors for background.
DHoude
Re: UI Suggestion - dark instead of standard white/grays
Post by DHoude »
Changing the button color and/or inserting button graphics really helps me.
Return to “General”
