Copy More then One Step At Once [fixed]
create lighting scenes
razortongue1
Post by razortongue1 »
When editing it would be great if there was a way we can hold down the shift button select multiple steps and then copy and paste them. This would save a great amount of time when programing. Keep up the great work. The program is getting better and better!
Re: Copy More then One Step At Once?
Added in TODO list, but no date for this.
Spaceman273
Post by Spaceman273 »
Any word on if this is possible yet? I would love to copy multiple steps but see no way of doing it other than one at a time. Thansk!
The function "Insert scene" helps a lot for this.
Spaceman273
Thanks! Where is this found on the editor? If i choose insert, it inserts another step, not a scene. I would like to copy multiple steps and insert them elsewhere later in the scene without having to copy and paste them individually. Thanks!
Spaceman273
Nevermind..... for those of you trying to do this..... If you choose insert from the file drop down, it will ask you if you want to save the existing scene, select yes or no, then you can select another scene to insert in the next steps. All steps from that scene will then be inserted. WORKING LIKE A CHARM! Would there be anyway to get this feature added on the drop downs from the editor page when you right click? There is an insert on the drop down which just adds a step, but an insert scene would be great there too without having to go to the file menu. THANKS!
We think it makes more sence to keep "step" functions in the "step" menu, and "scene" functions in the "scene" menu.
Return to “Editor”
