Video overview of 6.0 with DJ Mikey Mike
directsound
Post by directsound »
ShowXpress is out here is a video I did I hope it helps
http://www.youtube.com/watch?v=Ypta8F4GICE
Please leave some feedback so I can help you more
MM
_________________
The Best Parties Have One Thing In Common..... DirectSound!
http://www.directsound.com
DJ Mikey Mike
Thanks,
From DJ Mikey Mike
Re: Video overview of 6.0 with DJ Mikey Mike
We are not able to use this link.
Could you please check it ?
directsound
Here you go sorry abot the link I dont know what happend I hope you like it
MM
Thanks,
From DJ Mikey Mike
Thank you very much. We just made a new section called "Video from users", and we added a post with the link to your video. This will help a lot to start with version 6.00.
PS: the obligation to restart ControlBoard to see the changes made in Setup is an issue that we will fix in a short time.
directsound
OK what about when im in the editor and I want to see the pramoters of the fixture is there a way when you right click lets say on color to see the color list without having to take a nother step to show chanel values? Like a check box to let you always see the values like in 5.2?
thanks MM
Thanks,
From DJ Mikey Mike
Yes, it is still possible to show the values (popup menu) with one single left mouse click.
When the vertical size of the Editor window is big enough, there are now two places which show an icon, above each fader.
The first one is to call functions, just below the name of the fixture.
The second one is to show values, just above the fader (but the vertical window size must be big enough).
directsound
Got it thank you~
Thanks,
From DJ Mikey Mike
Return to “Windows”
