Variable Fixture Alignment? [fixed]
HUFSTUF
Post by HUFSTUF »
It seems that the fixtures 'snap to' an invisible grid or another fixtures line when in close proximity. I'm trying to create a COLORstrip workaround and need eight color changers side by side in close proximity. Is there a 'snap to' option that I haven't found or is it just the way the software works?
And a question outside the subject: on a fixture such as the COLORstrip that has 23 presets built in, would those presets be concidered 'scenes'? And if so is there a way do download those 'scenes' and upload them into the ShowXpress scene folder?
HUFSTUF
Re: Variable Fixture Alignment?
Post by HUFSTUF »
Found it :lol: . In case someone else has the same problem:
When in 3D view / 'stage', 'object' or 'fixture' settings / right-click in the room and an 'Auto Align' menu pops up.
Mine was checked 'On'. Turned it off and now I can place 'em anywhere :P
Re: Variable Fixture Alignment? [fixed]
Normally, the "Auto align" option is unchecked by default.
HUFSTUF
Post by HUFSTUF »
I'm running v6.30beta2. I may have inadvertently turned it on while first exploring the program :roll: . Also just now while looking for the 'About' section in the software I found it partially hidden in the popup menu.
Didn't know if this had been reported or not.
I'm a nubee at lighting and I'm lovin' this software! I've already bought a bunch of lights and have been programing scenes around those. Ordered the interface Monday and it should be here today, can't wait! Many thanx to you guys, keep up the great work!
Thank you.
Regarding the missing line in popup menu, it looks like, for an unknown reason, a file is corrupted.
A software re-install should fix the problem.
