RGB Tab in Editor
create lighting scenes
RGB Tab in Editor
Post by Pink LD »
When I use an RGB fixture I have noticed that I cant get the DMX value of 1 on any fader. It always goes from 0 to 2 when fader is activated and clicked or slid up. However when I deactivate the R, or G, or B individually or in any combination the RGB spectrum tab (second to the pant/tilt tab) shows the value to be 1.
I can't say that this has caused me any problems but it seems odd and I wonder what you have to say about it.
Thanks!
Re: RGB Tab in Editor
Thank you for this note.
This is due to a minor problem is Editor.
This will be fixed for next EXE file.
Post by Pink LD »
Thank you. I considered this fixed then. :D
Return to “Editor”
