Insufficient Channels
MediaDirector
Post by MediaDirector »
I have a pixel ribbon that has a lot of channels, currently the maximum channel for a fixture is 70. My ribbon needs 157 channels to be able to access all rgb led's and macros. can i do it without having to create multiple fixtures?
Re: Insufficient Channels
It is effectively presently limited to 70 channels in Setup.
It will be limited to 100 channels in next release.
Anyway, it is not a big issue, since you just have to create 3 fixtures and it will work same in Editor&Live.
MediaDirector
ok i have four of these 166 channel ribbons as well as several other fixtures, and once i get them loaded in the setup on two universes, the editor will not open. It crashes every time. i am running version 6.24 for mac.
The last version of the software is 6.281 (viewtopic.php?f=2&t=980), please try with it. If Editor still crashes, please send us your Lightshow.
Return to “Setup”
