second AKAI APC mini [fixed]
Bonifacedj
Re: second AKAI APC mini [fixed]
Post by Bonifacedj »
Bonifacedj wrote:
Niffo wrote:... 2 APC Minis, they should be always detected the same way as long as they are connected on the same USB port at boot time (preferably avoiding USB hubs). If they are not, you could always invert them in the Midi Preferences of the software.
i'm not sure what you mean by 'inverting' them in the Midi preferences...
Only since this morning i understood what you meant.
:oops:
I meant on the general midi preferences, this will avoid you to invert on each button ;)
Bonifacedj
Niffo wrote:...this will avoid you to invert on each button ;)
Yes, this is what i was doing yesterday morning... :roll:
So it's possible to avoid that, but i'm still not sure what you mean by inverting them in the Midi Preferences of the software.
Do i have to uncheck the MDI In and Out enable boxes, click apply, and then check them again and click apply again?
TheLightingController Preferences Midi.jpg (54.39 KiB) Viewed 13480 times
Bonifacedj
Bonifacedj wrote: Do i have to uncheck the MDI In and Out enable boxes, click apply, and then check them again and click apply again?
Oh yes, that is what i have to do.
With all the hassle and confusion related to my weekly blackout i forgot asking this before and got the answer already...which i didn't remember yesterday morning.
Bonifacedj wrote: Then i un-checked the "MIDI In - MIDI Out enable" (see attachment) and pushed "Apply".
Then i checked them again and pushed "Apply" again and the confusion cleared up.
Good to know :roll:
In the Preferences, the number in the column "#" IS the *device* number you can see in the midi settings of each button. AFAIK, uncheking/checking enable boxes is not needed after changing something in the midi Preferences grid.
