The problem seems to only happen on your setup since no other user has reported the same thing and we are not able to reproduce it. But when we knew that the "DMX BarGraph" did not open, we knew what part of the software did not respond so we inserted a security who relaunches this part of the software in case of no response. At this time, we does not know what caused the problem : it can be an OS issue, a conflict between hardware devices messages, and so on ...
But we will try to reproduce as much as possible.
Losing DMX signal using midi controller(s) [fixed]
Bonifacedj
Re: Losing communication with midi controllers [fixed]
@Niffo: thanks for your explanation.
Very clever approach.
So it's not a bug in the software since no user has reported the same thing.
hmm. strange.
Wil you insert this security in the next official upgrade, or do i have to stay with this personalized version?
hmm. strange.
Bonifacedj
I read there: "Fix for problem with multi midi devices using."support wrote:viewtopic.php?f=2&t=4658#p19502
But..
Anyway, version 8.2.3 finally prevented having a blackout after pushing al least one hour every one or two minutes on a midi device. Gig after gig, between one and two hours of doing that, i got a blackout.Bonifacedj wrote:
Used only one APCmini last night, directly connected through the left usb3 port of mijn MBA 13 inch mid 2013. In the only other usb3 port on the right, i've put my D512 DMX Interface.
90 minutes into the dancing part, same thing happened: lights gone, blackout.
Last night-gig, for the first time after a dozen of gigs in row with blackouts, i finished a four hours lasting party without a blackout while using four midi controllers (3 APCmini's and 1 novation launchpad).
Relief.
Thx again.
