Open in Editor
Later than version 6.31
Re: Open in Editor
Thank you John.
Same for you !
Re: Open in Editor
Post by Pink LD »
This still does not seem to be working for me.
When I select the "Pop up open in Editor is on pens a new blank scene but shows the correct path at the top of the window.
Re: Open in Editor
Ok, only occurs when Editor is not already launched and with scenes with path containing spaces. Will be fixed in next ControlBoard executable.
Re: Open in Editor
Post by Pink LD »
OK, thanks.
I always have Editor open alongside Live whether I am programming or performing...
Re: Open in Editor
Are you sure you are using the last Editor (0.7.6 - 121221) and the last ControlBoard (21/12/2012 - 922)) ?
Re: Open in Editor
Post by Pink LD »
Niffo,
Yes to Editor.
My Live About says "Live v2.15.9 - 121221 without..." and what looks like the top half of a "P" or a "B" followed by an "S"
Re: Open in Editor
Post by Pink LD »
I got my beta files from http://download.thelightingcontroller.c ... ware/beta/
That is correct right?
Re: Open in Editor
Post by Pink LD »
I just tested it again and it doesn't work if Editor isn't open but it does work if Editor is open.
Re: Open in Editor
Ok
JohnRichards
Re: Open in Editor
Post by JohnRichards »
Do not have that problem in Windows XP
Return to “beta files [closed]”
