Soft Patching [fixed]
tomrbland
Re: Soft Patching [fixed]
Post by tomrbland »
Nope, just the normal .txt file I'm downloading from herehttp://download.thelightingcontroller.c ... indows.zip
tomrbland
Post by tomrbland »
That confused me! I thought it was in the normal place! Found it now. Nice new feature.
Post by Pink LD »
Tom, Where is it?
I think I downloaded and installed it but I don't see where the feature would be. Can you help?
tomrbland
Post by tomrbland »
Within the program "DMX and Midi Patch" then the tab DMX output.
You can only patch 1-1 though you can't say type dmx address 1-10 = 35-45
It seems you have to say 1 = 35, 2 = 36, 3 = 37 etc
Post by Pink LD »
Support and Tom,
I don't see it? I see the DMX input screen. And I see the DMX Input just as it has been. I can can patch any of the up to 48 handles of a wing console to the software. But soft patching? Where? How?
I need to patch a House rig and dimmers of reds on Source 4 pars to one channel of my programming. I need to do the same for the other 5 colours as well as up to 12 Leko's
So if my software programming of my reds is in Ch 1 then all I need to do is patch where all the House reds are...
So I take the patch sheet from the House rig and patch the software. I.E. House red Source 4's are on Chs 1, 7, 13, 25, 31, 37 etc
And I soft patch 1, 7, 13, 25, 31, 37 etc to the softwares Ch 1 programming.
Therefore anything I do to Ch1 in the programming affects the associated channels I patch. I this scenario if I put up Ch 1, the reds on the house dimmers of channels 1, 7, 13, 25, 31, and 37 are brought up.
Thanks for your help.
tomrbland
Post by tomrbland »
Make sure you download this: http://download.thelightingcontroller.c ... ht_Win.exe You should now get a DMX output tab in the patch program.
But you don't appear to be able to do multiple outputs in the same patch.
So to do what you want to do I first tried: Channel=1 Outputs=1, 7, 13, 25, 31, 37
But this doesnt seem to work. I think you have to do it a channel at a time:
Channel=1 Outputs=1
Channel=1 Outputs=7
Channel=1 Outputs=13
etc etc
tomrbland
Post by tomrbland »
Sorry, it looks like I am telling you wrong again!!
It doesn't look like you can have multiple instances of channel 1. So you can't achieve what you are after. It looks like it is a simple 1-1 patch panel.
Support, is it possible to patch to more than one DMX output?
Post by Pink LD »
I don't have Sweetlight. Why would I download a fix for Sweetlight?
And for the record using the DMX Input screen put a plus (+) between your channels for multiple channels. Dmx Input 1= 7 + 13 + 19 + 25 etc....
marco
Post by marco »
finaly i got it working.
im using sweetlight
i did download the zip file,
and for multiple channels u use the +
for example slider 1= 3+5+7
slider 2 = 4+6+8
slider 3 =10+11
i only found 1 problem the slider that is the host (in my example 1 2 3 ) is also still aktive,is it possible to deaktivate this?
for showexpress i think support hasnt it put it online.
@LD did u try the sweetlight file if it works?
@support is it in the future possible to patch not the channels but the fixtures?it would save time
i would like to do it also for multiple channels like movingheads? or is this now possible?
ex channel 20-33 = output 100-133.
keep up the good work
Marco
We will release soon "clean" beta versions for all.
Right now, this is not possible in one action. This is possible only by entering one line per patched channel.
We add in the TODO list "DMX output patch - patch multiple channels in one shot"
the slider that is the host is also still aktive, is it possible to deaktivate this ?
Sorry but we do not understand this question.
Return to “Setup”
