3x Net 512 interface with Artnet [fixed]
Ethernet to dmx - web server - 9 buttons - calendar
autogedrocht
Re: 3x Net 512 interface with Artnet
Post by autogedrocht »
support wrote:Yes, please press "Autodetect interfaces" and tell us how many interfaces are found.
There are always minimal 2 interfaces found.
When i try only 192.168.1.35 it says 2 interfaces, same as for .45 and .55 individually.
When i try .35 and .45 at the same time, 4 interfaces are found.
When i try them all at the same time, 6 interfaces are found.
autogedrocht
support wrote:Please tell us also if the dmx output is running with all interfaces (sending value = 0 for all dmx channels).
When 6 interfaces are found and when in the hardware tab also 6 interfaces are filled in with an ip adress. -> No DMX is send to the output
When 6 interfaces are found and in the hardware tab i only fill in 3 interfaces ip adresses (other ones i fill ip .0 in). ->DMX is send to the output
see images
Even with one interface connected, the software see two interfaces !
In order to know if the problem is exclusively with your Ethernet network, could you please check on another Etnernet network ?
Another question
If you leave only the three first IP's and you delete the three last one, does the setup (software + interfaces) work well ?
autogedrocht
I shall try that.
Yes, that works good.
Question by me:
When you use only 1 net512 interface, you use the DMX output on 1 universe. How do you use the Artnet. Do you have to make another universe for only artnet?
So please do like this, and we will wait for the test with another Ethernet network.
Please follow this for Artnet: https://forum.thelightingcontroller.com ... =81&t=3741
autogedrocht
support wrote:Even with one interface connected, the software see two interfaces !
In my Business network it sees only 1 interface. (1 x net512) Like it the way it should be.
So, it looks like it is something in the router?
Yes, it looks like.
autogedrocht
So, any hints or tips?
We think the problem come from the router.
It may be better to change it (?)
In another hand, if it works like this, you may also leave the setup as it is.
autogedrocht
Re: 3x Net 512 interface with Artnet [fixed]
Ok
Well it works.
The most annoying part is that when you assign a interface to a universe, you see 6 interfaces. So how do you need which to pick?
It would be handy in every interface would get a number, maybe you can implement that in the future.
Or should i disable EnabelChnage DMX universes mapping?
Return to “Net512”
