I just did an important test:
- created a new lightshow on same computer
- copied fixtures.ini and fixtures directory from faulty directory to new lightshow : 3DView won't start ! That"s good information, problem is either in
fixtures.ini or one of the fixtures files.
3D Window (V5.1.0) won't start [fixed]
Re: 3D Window won't start
I look at the last modified fixture file from the faulty show
copied one I backed up recently
IT WORKS AGAIN
so this fixture file must have been corrupted.
Lessons Learned:
- frequent named backups, at least on config changes and major scene updates
- if this happens again I know 3Dview looks at fixtures.ini and individual fixture files.
Thanks for those who tried to help,
IT WORKS AGAIN
Lessons Learned:
Luc Henrion
Great ! Good job. Did you keep the corrupted file so you could check what was wrong with(in) it ?
Yes, if possible please post the "working" and the "corrupted" files.
This may speed up things for us to fix that problem.
Enclosed the faulty file. You will see that it starts with head "4" and ends with head "1"
I now recall I wanted to revert the order as moving heads appears in the reverse order i wanted. #1 was right and #4 was left. I wanted the opposite. So using Editor/Fixtures/Edit Fixture I moved each head using up and down arrows.
To confirm this was the problem I now reproduced the issue by naming heads "4" to "1": no 3Dview.
And moved them back "1" to "4" : 3D view fine.
3rd lesson learned : do no move heads order.
Is there a way to reverse heads for a multihead bar ? From left-right to right-left ?
- Hydrabeam4000(19ch) - faulty.txt
- Corrupted file
- (2.83 KiB) Downloaded 1394 times
Correct file
- Hydrabeam4000(19ch).txt
- Correct file
- (2.83 KiB) Downloaded 1396 times
Thank you for your help.
Fixed in the fix file.
https://forum.thelightingcontroller.com ... =85&t=3438
