V8.2.4 - stops working with fader on '0' [fixed]
Re: Sweetlight 8.2.4 stops working with fader on '0'
@Light_user : We were not able to reproduce the crash but we found a possible midi-loop case that we corrected in the 8.2.9 fix file, please try it : http://download.thelightingcontroller.c ... ew/fix.zip
@cedric : Nous n'avons pas réussi à reproduire le plantage mais nous avons trouvé un cas possible de boucle midi que nous avons corrigé dans le fix 8.2.9, pouvez-vous l'essayer ? : http://download.thelightingcontroller.c ... ew/fix.zip
cedric
Post by cedric »
j ai tester pour l instant pas de problème
cedric
Post by cedric »
sa a replanter un levant plusieurs fadeur en même temps
Process: TheLightingController [1705]
Path: /Users/USER/Desktop/*/TheLightingController.app/Contents/MacOS/TheLightingController
Identifier: TheLightingController
Version: 0.1
Code Type: X86 (Native)
Parent Process: ??? [1]
Responsible: TheLightingController [1705]
User ID: 501
Date/Time: 2016-12-23 18:18:49.829 +0100
OS Version: Mac OS X 10.12.1 (16B2555)
Report Version: 12
Anonymous UUID: D6DE0A3A-DA86-85B4-8C94-CF0FE06E12FB
Model: Macmini7,1, BootROM MM71.0220.B07, 2 processors, Intel Core i5, 1.4 GHz, 4 GB, SMC 2.24f32
Graphics: Intel HD Graphics 5000, Intel HD Graphics 5000, Built-In
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1600 MHz, 0x80AD, 0x483943434E4E4E384A54424C41522D4E5444
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1600 MHz, 0x80AD, 0x483943434E4E4E384A54424C41522D4E5444
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x13B), Broadcom BCM43xx 1.0 (7.21.171.47.1a8)
Bluetooth: Version 5.0.1f7, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: APPLE HDD HTS545050A7E362, 500.11 GB
USB Device: USB 3.0 Bus
USB Device: USB Flash Drive
USB Device: 2.4G Mouse
USB Device: IR Receiver
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: APC MINI
Thunderbolt Bus: Mac mini, Apple Inc., 26.1
cedric
Post by cedric »
j ai trouver pourquoi sa plante pour reproduire le plantage il suffit de lever les faders très vite et sa plante
On reproduit un problème avec V8.2.4, mais pas avec V8.2.9, même avec plusieurs faders.
Veuillez svp envoyer votre lightshow qui fait planter V8.2.9 .
cedric
Re: V8.2.4 - stops working with fader on '0'
Post by cedric »
re test avec la version 8.2.11 même plantage
cedric
Post by cedric »
pouvez vous me dire comment faire pour vous envoyer mon lightschow ?
cedric
Post by cedric »
je vous ai envoyer mon lightshow
cedric
Post by cedric »
Avez vous reçu ?
