Blinking and random dmx channels turning on
Re: Blinking and random dmx channels turning on
Please make this test:
- disconnect the dmx interface
- disable "Midi In" and "Midi Out" in the main menu "Preferences", and disconnect your midi equipment from the computer
- run the software and press some scenes
And let us know if you still see the problem.
BartKrap
Post by BartKrap »
support wrote:Please make this test:
Yes, I did that yesterday already, I wasn't seeing the issue then.
I connected the midi controllers, enabled everyting and it worked just fine for a while, tested a normal 30 minute "balls to the wall" manual show like I do in real life.
After that I left to go to work, I came back, moved some faders, mashed some buttons and it started all over again.
Luc Henrion
Post by Luc Henrion »
then it looks like a MIDI issue, don't you think so? No MIDI "loop"? No MIDI hardware sending a lot of unused/useless data?
BartKrap
Post by BartKrap »
Luc Henrion wrote:then it looks like a MIDI issue, don't you think so? No MIDI "loop"? No MIDI hardware sending a lot of unused/useless data?
Yes, I would have agreed with you but now I'm not so sure anymore.
I had all my dimmers assigned to the "fixture Midi inputs" before this problem came up. While testing I decided to use the "hard dmx/midi patch" and I'm not getting the blinking in 3d or random dmx channels popping up anymore.
Support, you can try to recreate this problem by first assinging the dimmers of different kinds of lights to the "fixture Midi inputs" using a (virtual) midi device and you can see random lights blinking white or strobing while they aren't getting a signal. Then try and assign those same channels to the "hard dmx/midi patch" and the blinking should be gone. Please look into this as it could be a show breaking bug.
(also, why is this post under V6, I'm definitly using V8)
Sorry, our mistake.
Topic is back in "General software" section.
Lothiam
Post by Lothiam »
We are having the same issue. Have tried USB hub powered and direct from pc for the controller. Blinking is not as pronounced after upgrading dmx cable from 512 plus controller to dimmer packs and dmx splitter /isolator.
Still happening, especially if using pc for anything besides lighting controller or even when saving scenes in show express. Multiple computer tested and have 8 gb of ram and about 25 % ram usage.
BartKrap
Post by BartKrap »
Lothiam wrote:We are having the same issue. Have tried USB hub powered and direct from pc for the controller. Blinking is not as pronounced after upgrading dmx cable from 512 plus controller to dimmer packs and dmx splitter /isolator.
Have you updated to the latest version?
Did you try a new usb cable?
Lothiam
Post by Lothiam »
We have tried different USB cables, powered USB hub, different versions/builds, replaced DMX cables with higher quality cable. I did try the most recent version 8.2.18 but it wouldn't let me have two solo pages with a scene loaded from each so back down to 8.2.10.
We are at the end of our rope and trying to figure out what our options are before replacing ShowXpress because we cannot find an issue. We have noticed that doing anything else on the computer compounds the issue.
BartKrap
Post by BartKrap »
Lothiam wrote:We have tried different USB cables, powered USB hub, different versions/builds, replaced DMX cables with higher quality cable. I did try the most recent version 8.2.18 but it wouldn't let me have two solo pages with a scene loaded from each so back down to 8.2.10.
What are the computer specs?
I'm looking for CPU, kind of harddrive/ssd, age, uses, installed programs, etc.
SeekLighting
Post by SeekLighting »
This is gonna sound kinda dumb, but have you considered that the problem may be unrelated to your controller? Sometimes a faulty DMX lead somewhere the in chain can cause this problem, have had it happen to me numerous times. Easy way to test this is to use your controller on multiple different rigs, or alternatively use a different controller (ie perhaps a hardware controller), and of course check all your DMX cabling.
