[El Capitan] - Showxpress Crashes after about 15 minutes
skywatcher
Re: iMac - Showxpress Crashes after about 15 minutes
Post by skywatcher »
in all fairness - I'm going to try the fix again to be sure I had the correct version - will let you know
Thank you very much for the tests. In the meanwhile, we have fixed the problem (we hope).
The next fix file (8.1.21) will include the fix.
Re: [El Capitan] - Showxpress Crashes after about 15 minutes
skywatcher
tried 8.1.20 again and software crashed - reloaded 7.1 and works fine - no crash after 24 hours - looking forward to testing 8.1.21
Yes, please try with 8.1.21.
It is available.
Jerminator
Post by Jerminator »
I went to download 8.1.21 but 8.1.15 is the latest available. Is there another place to download?
Mikedupproductions
Post by Mikedupproductions »
I'm having the same issue on OS 10.11.5 running 8.11.15. Crash happens every 15 mins to an hour while running in the background. 3d is not on and live mode just has a button depressed. Traktor is running in the foreground. No other apps are running.
benschrade
Post by benschrade »
I've followed this thread and have tried the suggestions with no luck. I still crash as soon as 40 minutes into launching. I've tried the latest fix (8.1.23) for OS X, however, it is unable to open with the error box reading, "EFK_Harware" not found. Earlier fixes still crashed with the added problem of not launching MIDI cues - this is a must. I've checked 'prevent app nap' for all versions plus 3D view. I have tried reinstalling all versions and recreating all light shows from scratch, but nothing has worked. I am currently running 8.1.00, which crashes, but launches MIDI cues. Please help.
Code: Select all
"EFK_Hardware" not found !!!
Are you using Sierra ?
If yes, please read this: viewtopic.php?f=10&t=4608
Return to “Mac OS”
