Channels not working properly with light fixture [fixed]
create lighting scenes
Re: Channels not working properly with light fixture
stirfrytv
Post by stirfrytv »
I downloaded the latest software 6.25, but the pan still did not work.
Actually no, there are no values visible in the dmx bargraph for the pan.
Considering the other channels have visible values in the dmx bargraph,
is the vertical line of channel 1 in dark grey color (like all channels), or is it in light grey color ?
stirfrytv
Post by stirfrytv »
It is dark grey. But one thing I noticed that is right after the grey line, the next line that comes up is for the upan, which I see the red line for. It would seem like there should be a gap between reserved for the regular pan, even though it does not show up.
If your interface is CABLE model, please check you are using software version 6.25, because we had a similar problem with an old software version (viewtopic.php?f=11&t=71&start=10).
If your interface is not CABLE, and your software version is 6.25, please change the address of the fixture, and tell us if you still can not drive its pan channel (like this we will know if problem is exclusievly for first channel).
stirfrytv
Post by stirfrytv »
Ok, the pan works now. I switched the channel to channel 2 and it worked perfectly.
Thank you very much.
This means that only channel 1 has a problem (exactely like software version 6.01 with interface Cable).
Please note that, if you make a lightshow with software version 6.01, and later you upgrade the software to more recent version, your lightshow will not work anymore.
Could you please tell us what is your interface ?
stirfrytv
Post by stirfrytv »
The interface is the Xpress 512 Plus.
Ok, so your problem is different than previously mentioned problem.
Could you please send us a copy of your lightshow ? (we would like to understand why you have this problem).
viewtopic.php?f=3&t=168
stirfrytv
Post by stirfrytv »
I am sorry, I am confused, what problem are you talking about? The problem with the pan that I had was fixed and now it works fine.
Return to “Editor”
