midi trigger
Re: midi trigger
On voit cette information dans ControlBoartd au même endroit que celui ou l'on sélectionne l'interface midi.
chris226
Re: midi trigger
Post by chris226 »
1. Obviously; make sure you have correctly installed the MIDI device on your computer. It should appear under: Control Panel > System > Device Manager (most likely somewhere under "USB")
2. Unlike previous versions; V6 does NOT show you the real-time MIDI input, when you select the "MIDI trigger", option for a button (it just lets you select a channel and note). To see the actual MIDI input, being recieved from your device, you must open the "DMX and MIDI inputs" box from the Control Board. Select the "MIDI" tab and check "Enable MIDI input" If you have more than one MIDI device connected to your computer make sure the correct one appears in the drop-down box (or it may just say "USB MIDI device")
3. The MIDI tab (mentioned above) should now show you the MIDI note currently being recieved by the software. You should use this as the reference while setting your MIDI triggers in LIVE.
Hope this helps. C
Chris Ping
Light and Sound Tech.
Art Bar
Lexington, KY
jaxx00974
Re: midi trigger
Post by jaxx00974 »
And dont forget, there is no natural midi input selection on Vista/ Win 7 so you must use a third party app called midi picker to choose your device in windows.
Lee.
Return to “Buttons”
