Master fader > Edit > wrong channel # displayed [fixed]
Detour DJ
Re: Master fader > Edit > wrong channel # displayed
Post by Detour DJ »
The "Dim" buttons that I created work correctly on the channels I assigned them to control. Like other buttons, they link directly to the fixtures and have nothing to do with the Live Page Master Faders, as I had them designed months ago. It's the new Master Fader slider in v6.33 that hasn't seemed to work as intended. Admittedly, I haven't had a lot of time to experiment with it, but I'll try to take some time tonight and see what happens. Up to this point, I quickly assigned the Master Fader to what was labeled "dimmer" channels for my Chauvet 4Bar Tri's and Blizzard Snowbanks, but it had no effect. That's when I noticed it listed the wrong DMX channel values and figured that might be the reason.
Thanks!
Larz Hanson
Owner-Operator
Detour DJ, Sound & Lighting
7431 Frontage Road NW
Cleveland, TN 37312
(423) 432-3489
DetourDJ@gmail.com
http://www.DetourDJ.com
Detour DJ
Post by Detour DJ »
Hi Guys,
Sorry for the long delay in finishing up this thread. When I finally got the time to sit down and really play around with the new software, I realized a few things:
1) As you're aware, the numbers aren't lining up on the Master Fader edit window. I'm sure you'll have that fixed soon.
2) The Master Faders ARE working correctly, but only after...
3) I had to go back to the Setup screen and rewrite my profiles using the default "dimmer" selection. I've designed most of my profiles as some of my fixtures were brand-new on the market when I first started using them, and some were using custom settings for "dimmer". They worked fine for everything up to v6.33, but this version exposed the need to use default dimmer settings over custom ones.
4) All is well now...keep up the great work!
Larz Hanson
Owner-Operator
Cleveland, TN 37312
(423) 432-3489
DetourDJ@gmail.com
Thank you for the feedback.
Return to “Buttons”
