[V6.33] Macros
Shakes
Re: [V6.33] Macros
Post by Shakes »
Done a complete reinstall (again) and still have the same problem.
Looks like I'll learn to live with it for now.
Re: [V6.33] Macros
Do you have sent to "support" the smallest lightshow possible to permit us to see that something works differently in v6.32 and v6.33x as asked ?
Regards.
Shakes
Re: [V6.33] Macros
Post by Shakes »
Hi Niffo.
They've had 2 shows and found some coding errors which were downloaded in a fix file.
It's as if certain scenes within a macro aren't recognised if you manually overide them.
Frustrating but not the end of the world.
Re: [V6.33] Macros
You can try with the last "Fix File" (be sure to use the last 6.332 version before), there is a good chance your issue is fixed.
Shakes
Re: [V6.33] Macros
Post by Shakes »
I still have this problem with some scene buttons not registering when stored with a macro. Typically it'll be a dimmer scene so instead of a head moving in darkness, the head moves with the light on to it's new position. Head/Scanner position and chase scenes are in a live window with solo buttons and dimmer, colour, gobos etc are in a seperate window called "masters" which do not use solo buttons.
Macro's that have been created and used in older versions are fine but if I change any scene and update the macro, move in dark stops being recognised. This was all fine before 6.33 - You've already had copies of the show and can't reproduce it but it happens on all 3 of my Windows computers. (Laptop - Vista / Laptop - XP / Desktop - XP)
It's starting to get annoying now as I can't modify macros without damaging them!! - Could it be a button priority issue and if so, is there any way of forcing a delay?
I really could do with some help on this please anyone.
Re: [V6.33] Macros
Can you please post the smallest possible lightshow illustrating this problem ?
Re: [V6.33] Macros
Please, can you verify in ControlBoard that you are right using version 6.333 (not 6.332)
Shakes
Re: [V6.33] Macros
Post by Shakes »
Deffo using 6.333 and show sent.
Cheers
Re: [V6.33] Macros
Sorry but we are not able to reproduce the problem.
PS: the lightshow you sent to us has 145 scenes used in Live, so it is indeed not easy to understand it and then try to reproduce the problem. If you could send us a lightshow with max a few scenes, and a new page in Live with only a few buttons, that would help us a lot to reproduce the problem. To do that, you can make a copy of your lightshow, and then delete the unnecessary scenes files and unnecessary pages in Live.
Shakes
Re: [V6.33] Macros
Post by Shakes »
;) Ok. See what I can do.
Return to “Buttons”
