Problem with mp3 files with res higher than 128Kbps [fixed]
compforce
Re: Problem with mp3 files with res higher than 128Kbps
Post by compforce »
I sent the file a couple of days ago and have no acknowledgement or response. Did you get the file I sent? Have you had the chance to take a look? I'd really like to know as the timeline was my whole reason for buying the Xpress 512 and I will return it if the timelines aren't going to work.
We got the file. We are able to reproduce the problem.
We are presently working on another urgent bug to fix ; we will come back to you as soon as possible.
The problem is clear now. We added one "note" post for it. Please read it: viewtopic.php?f=30&t=2027
In other words, if you install the codecs pack, TimeLine will play correctly your mp3 file.
Lighter007
Re: Problem with mp3 files with res higher than 128Kbps [fixed]
Post by Lighter007 »
You have to use uncompressed Media files! I`m using WAV.
Greetings from Germany! :)
Return to “TimeLine”
